Beyond Blue
Cozy MKIV
Trim and Sand Seat Brace and Heat Duct
Removed peel ply from the 2" BID tape on the seat brace/heat duct joint.
Trimmed the fiberglass edges using a small hand saw.
Sanded the taped joint and vacuumed the assembly and work table.
Sanded the bottom of the heat duct flush with the lower fuselage longerons.
Temporarily clamped 2 x 4s across the bottom of the fuselage to ensure the bottom of the heat duct was level with the longerons.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
