Beyond Blue
Cozy MKIV
Chapter 6
2" taped joint for heat duct and seat brace
Cut out 2 plies of BID at 45deg orientation to make two 2" x 17" pieces of fiberglass tape.
Workshop temperature was 25deg C and humidity 33%.
Mixed a batch of epoxy using 116g resin and 44g hardner. Poured a small portion into a cup and added flox.
Applied epoxy to the 2 ply layup and applied flox to the joint between the seat brace and heat duct to ensure it was smooth.
Cut out the 2" x 17" BID tape using electric scissors and applied them to the joint on each side of the assembly.
Placed peel ply over both joints and wet it with epoxy.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
