Beyond Blue
Cozy MKIV
Chapter 6
Install safety belt tube in heat duct
Removed the clamps from the heat duct following overnight curing.
Fabricated two safety belt anchor points by cutting two 2" lengths of 3/8" diameter 2024 aluminum tube.
Removed foam from the heat duct for one of the safety belt anchor tubes and the fuel line.
Shop temperature was 23 deg C and 48% humidity. Mixed 15g resin and 6g hardner with some flox.
Floxed the safety belt anchor tube in place ontop of the heat duct.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
