Brief Description: Installed bottom right side spacers
Workshop was heated to 25 deg C and the humidity was less than 30%.
I used 2 batches of micro-slurry for this. Each batch consisted of 36g resin, 14g hardner, and 1 scoop of glass bubbles.
I applied the micro to the PVC foam using a squeegee then I applied micro to the bottom of the spacers. Starting at the aft end and working towards the front, I applied nails into the foam to temporarily hold it in place and to follow the shape of the bottom of the right fuselage side. I used books between the nails to weigh down the spacers while they cure.
