Brief Description: Shaped Left side spacer EE piece #1
I used the band saw to cut out a length of Last-a-foam 3" wide. This piece was traced onto the bottom of the left fuselage side where it will be used. Next, I used a table saw to bevel the edge as per EE on Figure 7 then used a scrap piece of Last-a-foam to sand the beveled edge. I will leave the table saw as is so I can bevel the remaining EE pieces to match this first one.
