Clamped foam fuselage sides to forms at the aft ends.
Put several dabs of 5-min epoxy at the bend in the middle of one fuselage side. Then put several dabs of 5-min epoxy at the front end. Removed clamps and put several dabs of 5-min epoxy at aft end. I used Aircraft Spruce catalogs as weights.
The steps were repeated for the 2nd fuselage side.
