Beyond Blue
Cozy MKIV
Chapter 5 Step 2
Sand & 30 degree lines
I sanded the hardened 5 minute epoxy where the foam pieces were epoxy'd together. I vacuumed the foam fuselage sides after sanding.
I added 30 degree lines to show the directions for placing the 1st and 2nd layers of glass cloth.
Lastly Sophie and I cleaned up the shop floor.
Sophie is either a QA inspector or Sherlock Holmes ???
30 degree lines
QA Inspection of bulkheads
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
