Brief Description: Add length and trim fuselage sides
5 minute epoxy was used to secure smaller pieces of foam to the rear end of the fuselage sides to extend the length as required.
Once cured, the masonite forms were used to trace the shape on the ends. A utility knife was used to trim the shape of the rearward ends of both fuselage sides.
Both fuselage sides are now 102.5" long and the bottom (curved) sides are slightly longer than called for in the plans (as recommended by numerous other builders).
