I've noticed a few clumps from the hardner dispenser so I pumped the hardner into an old hardner container and the resin into the resin bottle. I'll re-use the resin but the hardner has expired so I won't re-use it. Once I got most of the hardner out of the pump by pumping it out followed by pouring the rest out, then I cleaned the pump's hardner container with a paper towel then I half filled the container with vinegar. After a combination of pumping then pouring out the vinegar, I repeated the exercise with hot water.
On Friday I'll swing by Aircraft Spruce Canada to pickup more resin and hardner and a few other supplies so I can finish glassing F22 next weekend.
I layed out the mixing cups, sticks, brushes and squeegee's for the next layup.
