Larrys Web Site
Date:  6-13-2017
Brief Description:  Fuel return line
Firewall forward kit has all the fuel lines and oil lines premade with fire sleeve attached. All I had to do was install the lines. First line was from engine to check valve. Second line was from check valve to firewall. Still need to put on Adel clamps for support and cut hole in firewall. Will probably use a bulkhead fitting instead of a grommet.
Installed return fuel line from engine to check valve
Fuel check valve
Fuel check valve
