Larrys Web Site
Date:  10-31-2017
Number of Hours:  1.00
Brief Description:  Avionics Arrives
Finally got avionics package from Zenith today. Unboxed all parts and laid them out on table to see them. Only item I found to be missing was VHF antenna and one prat which is on backorder from Dynon. It will be a while before I need either of these parts so that is no big deal. Also got instrument panel template from Zenith. Called Roger and suggested to him that if they are going to cut out hole in template for the ELT manual switch, they should check with customer first to see if that is what customer wants for their ELT. Also if it is what they want, then Zenith should provide it in the package. Roger said he would consider this. Got all the installation documents and will start reading up on how to get started. This should be fun!!
Table top covered with all new avionics from Zenith
