Safety wired the ailoeron cables shown in photo 3. This was the hardest job so far on building this plane. Whoever thought this was a good spot to put the turnbuckles obviously did not have to safety wiire them. There just is not enough room to neatly get the safety wire around the turnbuckle. I final got it done but it is not very neat but it is functional. And yes as you have probably noticed by now, the rudder call is on the wrong side of the torque tube tong!!!##(: I would have fixed this today but I just did not have the desire to take safety wiring off today after all the energy I spent on putting it on. I will remove wire tomorrow and get cable in the proper position. Note to anyone getting ready to connect aileron cables to the torque tube. When I ever have to adjust aileron cable tension, I will remove safety wire on aileron turnbuckles and then move turnbuckles out from under control stop. Yes I will have to make up another small cable but that will be much easier than trying to deal with turnbuckles under the control stop. Trust me!
