Got light wired up a few days ago but when I checked them, the right wing strobe light would not work. So today, I removed the right wing light fixture and as luck would have it, there was just enough extra wering to allow the fixture to be removed and also pull out the molex connector. Once I get the connector out, I saw what the problem was. The white power wire for the strobe had pulled loose from the molex connector. I removed the pin from the connector and got a new pin and crimped the wire on the pin and inserted pin into molex connector. Put everything back in place and reattached fixture to wing. Now nav and strobe lights are workin on right wing.
