Temperatures warmed up again today so I worked on the coax cable that connects the ADS-B transceiver to the antenna. Used RG400 cable since it will be routed along with the transponder cable. This was suggested in the Dynon installation manual. Put BNC connectors on each end of cable and temporarily routed it from antenna shown in photo1. Photo 2 shows cable routing from under passenger seat up the sdie wall an then forward to the ADS-B module. Photo 3 shows end of cable resting near the instrument shelf waiting on the installation of the ADS-B once it arrives. Also laid out holes for the pilots and passenger headset jacks. These will be located at the bottom of the center console panel below the fuel selector valve which is the location they are in the demo airplane.
