Completed all the required rivetting on the rear trim pieces. Still need to disassemble, deburr, corrosion protection and weatherproof ttim pieces. Also need to put heat shrink tubing on all tubes and paint side rails. This will be done once I get the front canopy tube riveted to the canopy. I will also need to drill holes in front and rear canopy to final size for rivets and screws. Lastly, the trim peice that goes over the gap between the front and rear canopy will need to be fabricated. It seems like the work on the camopy wiill never end but I think I can see the blue sky at the end of the runway!
Rear canopy trim riveting completed
Same for right side on rear canopy
Rront canopy tube frame resting prior to installation
