Installed mass balance weights and strike plates in right outboard section. Also installed right nav/strobe light and completed wiring. Right wing tip installed and all A4 rivets were pullied. Got started on A5 rivets but stopped once I had inseted A5 rivets in open holes. Will start tomorrow with pulling all the A5 rivets. Then I will need to flip wing again to install flap and set aileron stop and adjust bellcrank arm. Should be able to complete right wing this weekend.
