I will need some assiestance before I can continue working on wings since I need to turn both of them over and it takes at least two for this and three is even better. So while I await some volunteers, I decided to insstall the elevator stops. Before cutting out the stops from the fairlead material, I had to set the up and down travel limits. Plans show max and min settings so I set mime between the max and min. ( 13.5 degrees down and 31 degrees up). Just need to make sure everything is level before and find neutral position for elevator.
