Continued work on right wing rear bottom skin. Got it aligned and drilled out to A5 size. Nose ribs attached and nose skin laid on and drilled to A4 size. The big test comes when you turn the wing over and see if the nose skin will overlay the spar just right for drilling. It worked on the left wing so I see no reason it should not fit on this wing.
