The last step in installing the prop spinner is the plate behind the prop. It's tricky because it needs to be the same thickness as the spinner and bent to the same shape as the spinner.
I was able to make the pattern but when I tried to bend it to the shape of the spinner, I just goofed it up. Time to head home
