While the panel was still temporarily installed in the plane, I tested different ways of running the wiring for the heated seats. (I had installed the switches earlier) I decided to run the inline fuses back to the same area that all the other fuses are at. (Behind the GPS) Then, the wires come back to the switch area. It seems to be the cleanest and make the most sense.
