I worked this afternoon on fitting all the components into the panel and making some minor adjustments.
I enlarged the radio stack hole a bit. Enlarged all of the holes for the insturments. (They were not drilled quite large enought. I also enlarged the opening in the bracket that holds the instruments on from the back. The hole was not big enough.
