Brief Description: Yet another day working on the Canopy Frame
After searching a number of builder site, I decided to wait a bit on the skin scraping. Almost everyong says as you work more on the frame, things get back out of whack...
This evening I started getting ready to work on the aft part of the canopy. First, I clecoed and bolted in the roll bar only to find I hadn't finished putting in the pull rivets in the back part of the channel.
I put in the rest of the rivets. (Probably about 50) I worked a bit longer... but my dang wrists hurt from using the hand rivet gun. So, I worked on cleaning things up and laying everything out to see how things will go together.
There will be a lot of fitting to get the rear flanges correct. (I'll wait until my wrists feel better:-)
