This evening I worked on attaching the hinge brackets to the forward fuselage ribs.
- Started by attaching the F-644 Fuselage Channel - Clecoed the forward skin on (all clecoes for the ribs and channels - Unclecoed a side of the skin at a time and drilled the holes the rest of the way through the hinge bracket - After drilling, I installed the bolts and checked the alignment of the canopy brackets - The pivot holes line up almost perfectly to the markings on the brackets!
