I started out this evening working on the canopy frame. The right side lines up correctly with the fuselage. The left side doesn't. I've tried about everything I can think of. I finally decided to put it on hold for a bit.
So, I dove into working on the pitch servo mount for the auto pilot. The instructions that came with the Dynon unit were clear and the installation was actually FUN. I ended up using six bolts to hold the bracket in place. I was going to use rivets and bolts but thought if I wanted to remove it bolts would be easier.
