I started out this evening working on a few things I've been putting off. The first was to remove two bolts from the center spar. When we had torqued the bolts last month, there were two that the nut didn't budge a bit and they were to the limit. I was worried that when I installed them, I over torqued them before I realized what little amount you need to tighten them. So, to be on the safe side, I just removed them and re-torqued them.
Next, I put a drop of torque seal on all of the nuts we had torqued. From now on, when I torque one, I'll put a drop to remind me what I completed.
I also bent the fuel float rods. The directions say to check how they fit in the tank BEFORE you skin the tank. Since I have the quick build wings... that's pretty tough. So, I bent them exactly like the directions say. I'll do some Googling to see what others have done with the quick build wings.
