Dang it was hard bending the forward fuselage side attachment point. I finally ended up using a sledge hammer to get the thing to bend. (This was after spending 45 minutes with a large hammer.)
After getting the attachments to fit correctly came the scary part. You need to drill from the inside of the fuselage out through the attachment point. After measuring a zillion times, I drilled a small hole on the left side. It looked good so I finished drilling the top and bottom hole.
I wasn't so lucky with the right side. The bottom hole was drilled to close to the bottom of the attachment point. So, I ended up fabricating a new one. I decided to wait until tomorrow to bend it.
