This afternoon, I fabricated some parts for the wing attachment. The fuel tank attach bracket is made from giant aluminum angle iron stock. It took some MAJOR fabricating. I made the major cuts with the band saw. (Going VERY slow) Then, shaped them the rest of the way with the table sander and grinding wheel.
The reinforcement angles were pretty straight forward. Just shape some angle iron using the hack saw. Then, finish the work with the table sander and wheel.
I also finished the rudder cable covers. (I'm not sure if I am going to use them.)
Drawing out the cuts
Finished Tank Attach Assembly and Reinforcement Angles
