I cut the other wingtip lens to size and installed the nutplates using the small pull rivets. (Like I did on the other wingtip.)
Next, I installed the wing lights. I attached the LED lighting. To keep the circuit board away from the fiberglass I used plastic washers. (The soldering in the back sticks out a bit.)
The landing light is recessed behind the position light assembly. The washers that hold the long bolt needed to be trimmed to the correct shape. I out the plastic washer on a bolt to hold it while I sanded it on the table sander.
