- Cut rudder fairing to size - Marked and drill holes in the fairing. - Drilled holes through to rudder frame - Marked and drilled rivet plates - Countersunk for rivets - Riveted rivet plates in place - Countersunk fiberglass for screws. (Test fitted everything)
(I started using a washer on the outside of the fairing. The screws fit much better with just countsinking them. I think I have the close enough so the washers won't be needed.)
