Considering how much time I've taken fretting about these holes, drilling them was anticlimactic. I just basically followed the direction and drilled them.
- Marked the aft horn - Drilled pilot hole - Using a hardwood board with the same size hole, drilled through to the other horn. - Enlarged both holes using a step drill bit.
