This evening I glued the trailing edge of the elevators. Hopefully, I didn't let as much ooze out and it won't be as much of a headache to clean up. (The rudder trailing edge was good practice) I put some wax paper between the skin and the aluminum bar used for alignment. It was Cormac's idea to help keep the skin from sticking to the bar.
I also glued the foam wedges into the trim tab.
The empennage is getting close to being complete. I'll set these aside for a week and let everything dry. (I'll take the clecos out a few times and make sure I'm not glueing them permanently in place.)
