Brief Description: Step 94 Install the spring blocks & attach bracke
-mark location of front and rear spacer blocks and brackets on tailcone-remove tailgear and brackets-remove white primer within marked areas -mix 20 grams resin/mill fiber -clean sanded areas and bracket bolt locations inside tailcone with acetone-apply resin mixture to top of both spacers and rear spring brackets -assemble tail gear and spread resin under large washers in tailcone-tighten all fasteners and remove excess resin from around mating surfaces
