Brief Description: Step 92 Bolt the springs in place....
-bolt spring stack to tailcone-clamp straightedge to stabilizer support bracket parallel to attachment bearings-mark reference lines 8”out from centerline-check alignment of springs by measuring from rear holes to straightedge ref. marks-check fit of aft attachment brackets, both required bending in vice to match tailcone-clamp brackets to spring and jack up bottom of springs until brackets seat per drawing-drill pilot hole through bracket and check hole position relative to radius of joggle-adjust position of brackets allowing room for large washers inside.-drill 4 holes and bolt brackets to tailcone-recheck spring alignment and remove entire assembly-prime brackets with zinc chromate, vacuum tailcone
