-Assembled the bellcrank for the elevator.-Measured the vertical distance between the bellcrank brackets and ensured it corresponded with the dimensions given in the manual. -Levelled the bellcrank brackets unto bulkhead C and outlined the bolt holes. Ensured that the edge distance was grater than 3/8”. -Drilled the bolt holes in bulkhead C.
