-fuselage jigged to 0 degrees on the waterline-stabilizer angle set at -1.4 degrees-stabilizer set perpendicular to waterline by measuring from wing strut attachment points to leading edge of stab-rear mounting bracket shifted until both measurements were equal -rear mounting brackets drilled to ¼”-aluminum re-enforcement plate for bulkhead E manufactured from .125 aluminum plate
