I started by taping the ruder so that it was straight. Then I fit up the graphics on the R/H side of the vertical stab and positioned for best fit. I didn't like the way the Kitfox Sport script was on a bit of an angle. So I cut it out from the rest of the graphic. And will install it separately. I then applied the graphics the same as done on the main gear wheel pants. Then repeated the process on the L/H side of the stab. Making sure to keep the positioning the same as the R/H side.
