Brief Description: main gear wheel pant installation.
Installed recently painted main gear wheel pants. And positioned main wheel pant graphics in place and marked location. Then removed the graphic and cleaned surface of wheel pant for installation. Removed backing from graphic and sprayed with rapid tack solution. Also sprayed the surface of wheel pant. And carefully positoned graphic in place. Then squeged out the fluid and air. And repeated the process for the other side.
