Rolled out some fabric to cover the top of the R/H wing. And began bonding to rib #1 and working my way out the the tip. Then bonded the leading and trailing edges. With a 2" overlap at the leading edge. And a 1" overlap at the trailing edge. It was a bit tricky to get the leading and trailing edge lines to stay straight as I bonded it down trying to avoid getting too many wrinkles.
