Located and drilled up both door latch housings. Disassembled, debured, and prepared mating surfaces for epoxy bonding. Then bonded and riveted door latch housings to door frame. Fabricated door latch handles from flat stock. Then drilled and countersunk holes into door latch blocks. Attached door latches and latch blocks with countersunk screws. And fastened assembly to latch housings.
