Reamed pivot hole to size. Drilled up a very small 1/16" hole in detent pin for the role pin to lock it in place. Had to open up detent pin slot a bit. Assembled slider, spring, detent pin, and handle tube. Secured slider, spring, detent pin, and handle tube. Secured detent pin in place with roll pin. Then installed assembly in fuselage.
