Kurt Haller RV-9A
Date:  2-7-2012
Number of Hours:  1.50
Manual Reference:  8
Brief Description:  Rudder block holes in F-719 & F6118
Drilled rudder adjustment holes. Pitch of the front holes for the UHMW block is 0.8". Total of 5 possible positions. Smoothed edges of center rudder bar support bracket and the F-684s.
Decided to fill the odd rudder UHMW block hole in F-719L with JB Weld. This is NOT advised for a hole that must bear a lot of shear load. Will smooth the good when cured and re-drill using the block as guide.
