Brief Description: Torque tube end plate, fuel shut-off, N number
4/20/20 2.9 Hours Drilled a hole in end of wing fuel shut-off valve for safety wire. Worked on torque tube end plate.
4/21/20 Received check-list from DAR 2.9 Hours Finished drilling holes for the torque tube end plate. Drained the little amount of fuel in right wing. Cut out about an 1 1/2" of fuel line at right root and inserted quarter turn fuel shut-off valve with hose clamps.
4/22/20 2.2 Hours With Paul's help, applied "EXPERMENTAL" to back bulkhead. Applied 4" registration numbers to side of fuselage.
