Jay's Cruzer
Date:  5-27-2020
Number of Hours:  8.60
Brief Description:  Refine engine, pre-inspection
5/24/20
2.3 Hours
Re-torqued prop clamp bolts. Safety wired the prop mounting bolts. Added chaffing tape to engine mount where I had wires and lines zip tied to frame. Got 8 out of 10 done
5/25/20
.7 Hour
Finished adding chaff tape tape to engine mount. Added marks on coolant overflow bottle at half and three quarters.
5/26/20
2.6 Hours
Opened the inspection panels. Installed the cross member in bottom of fuselage. Armed ELT and tested.
5/27/20
3.0 fHours
Paul did a pre-inspection for me. Scheduled DAR is 5/30/20. He found 19 issues, anything from loose jam nuts to things rubbing on each other. Corrections takes from a few seconds to a whole lot longer.
Paul pre-iinspecting
