5/29/19 4.3 Hours Finished splicing left PPT wires to harness and zip-tieing into place. Spliced GPS antenna leads to harness. Made new center console L angle bracket and riveted into place. The old one had the console off-center.
5/30/19 4.3 Hours Riveted #8 nut plates to new center consoel bracket. Seat base on and off several times to make sure bolts for seat rails did not bind. Riveteed right seat base. Had to remove rear latch strike plate to be able to rivet below strike plate then re-riveted plate.Unable to get at one A4 rivet hole located underneth door jam. Installed rails, seat pan amd seat back. Climbed in to check leg room (I have long legs). Better than alot of aircraft. I think the pilot seat can be installed 1 1/4 to 1 1/2 inchs aft to give a little more leg room.
5/31/19 3.2 Hours Marked 11/2" foreward then drilled holes in forward pilot seat base. Removed right seat and clamped to pilot seat. Backed drilled the two rear holes. Marked location for the two larger holes and used step drill to drill thoes.
