Jay's Cruzer
Date:  5-22-2019
Number of Hours:  8.90
Brief Description:  Instrument Panel
5/20/19
2.6 Hours
Put three screws around the map box.Tried to mount the 12V power plug but turned out one of the screws was a #6. Clecoed inboard L angles stifferners for upper foreward skin. Dressed holes for intercom and radio head. Drilled hole in center cionsole for padded clamp to support mic/headset wires
5/21/19
3.7 Hours
Put other #8 screw in 12V power plug. Spliced, using butt connectors, three wires from the trim indicator and two wires from trim rocker swithc to the trim cable. Placed Dynon modules and trim in place to see how it looks. Next one will be a little different (HaHa). Red knob on center console is parking brake. To its right will be cabin heat knob
5/22/19
2.6 Hours
Installed #8 clip nuts (5 each side) to floor L angels for center console sides to attach. Installed with tiny, tiny screws the trim rocker switch and indicator. Installed one #8 nut plate for center console cover to attach to instrument bulkhead. Need another short nut plate.
