I took the tail spring to Clark Oilfield Measurement Inc.'s machine shop to have the hole enlongated per the instructions provided by Avipro. They did a great job, thanks guys. Also had to grind down the width of the spring a little to fit the tailwheel.Then had to ream out the fuselage for the AN7 mount bolt and drill two holes in the rear mount boss for the U bracket.
