Brief Description: Rivet left rear spar and prime main ribs
Riveted doubler plates to left rear spar. Prepared main ribs for primer. Skuffed riibs lightly with maroon scotch brigh pads and cleaned with laquer thinner. Primed all main ribs with Sherwin William P200G green wash self etching primer. Time extended because of difficulty with spray gun. After priming more than half of the ribs discovered that the problem was that the air vent in the paint resevoir in the gravity feed gun was blocked. Once this was fiix, work went much faster.
