Filled tooling marks off edges of skin for left wing leading edge using Vixen file and rounded edges using v-shaped edging tool and scotch bright pads. Rounded corners. Removed protective vynal coating along rivet hole lines on outside surface and all vynal from inside. Fit two ribs. Fit is very tight at the nose end of rib.
