Brief Description: Rivet tank attachment platenuts
Completed riveting left spar tank attachment platenuts. Primed all counter sunk holes using small amount of zinc oxyde sprayed from a rattle can into a small container and applying with a que tip. After setting several rivets, I decided that the counter sinking was not quite deep enough. Removed all clecoed platenuts. Counter sunk a couple of holes a notch or two deeper, primed and set rivets. After confirming that counter sink was deep enough, proceded to counter sink all holes on left spar, primed and riveted platenuts to spar.
