Brief Description: Elevator Counter Weights and Fitting
Over two sessions, fit the left and righ elevator to the horizontal stabilizer and mounted lead counter weights. Elevators need further adjustment. When deflecting left elevator into full up position, the leading edge contacts and rubs against the rear HS spar. The right elevator does this to a lesser extent. The leading edge curve appears to be slightly off plan and needs attention. Also assembled and riveted the VA-146 bearing.
